Use this task to view IPv4 Address Resolution Protocol (ARP) information.
- Expand Mgmt Instance.
- Select Mgmt.
- Select the IpArp tab.
IpArp Field Descriptions
Use the data in the following table to use the IpArp tab.
Name |
Description |
Address |
Shows the IPv4 address of the ARP entry. |
Instance |
Shows the Management Instance ID. |
IntfName |
Shows the Management Instance interface name for the ARP entry. |
MacAddr |
Shows the MAC address for the ARP entry. |
State |
Shows the state of the ARP entry. The state can be one of the following:
